Sat Dec 20 2025
Mamografo
Tengo estos errores 25:8 y 25:11 error de captura de imagen y 25::11 filament calibration is recommended
Equipment: Hologic selenia dimensions
Translation: I'm getting these errors: 25:8 and 25:11 image capture error, and 25:11 filament calibration is recommended.
   RE: Mammography Report Post
Fri Jan 02 2026Reply from Jlinton
Jlinton
On Hologic Selenia Dimensions, 25:8 and 25:11 are X-ray chain–related image capture faults.
  • Run Filament Calibration from service mode first
  • If calibration fails or the errors return, suspect tube aging, filament instability, or the HV tank
  • Check recent line voltage and confirm no intermittent power issues
  • If exposures are inconsistent or noisy, this usually ends in tube replacement, not detector work
