Mon Dec 22 2025
Is there's a way for more comfortable work?
Is there is a way to lift the cryostart when servicing it in the field instead of crawling on the floor and working on my knees is there is a jig or two so someone of you is using for that or do I have to stick with the knee pads
   RE: Cryostat Report Post
Mon Dec 22 2025Reply from Ross
In the shop I use a hydraulic cart (from Harbor Freight) onto which I have bolted a piece of plywood. In the field, kneeling mats help.
Tue Dec 23 2025Reply from Peter N
hi,
thanks for your reply. how do you lift it on the cart,  ramps?
do you have a  photo how it looks?
Thank you!
Tue Dec 23 2025Reply from Ross
Yes, I use a ramp and an appliance truck to pull it up onto the hydraulic cart.
Wed Dec 24 2025Reply from Peter N
I am going to try  and build something. if it works .will send you the details.
