Fri Jan 09 2026
Vertical lines on processed images.
Hello team,
  • How do I deal with this? have tried to calibrate, but still getting this. Vertical line artifacts are present on processed images only
  • RAW images are clean
Equipment: Hologic -Lorad Selenia Mammogram
   RE: Mammography Report Post
Fri Jan 16 2026Reply from Jlinton
Jlinton
If RAW images are clean and the lines only appear after processing, the detector is fine. This points to:
  • Image processing / calibration file issue
  • Corrupt or outdated flat-field / gain calibration
  • Software artifact, not hardware
What to do:
  • Re-run detector gain and offset calibration (full, not quick)
  • Clear and reload calibration/processing files
  • Check for recent software updates or roll back
  • Reboot system cold (power off fully)
If it persists, it’s almost always a software or calibration database problem, not the detector.
Fri Jan 16 2026Reply from loise
Could you guide me on how to do it? please
