Fri Apr 10 2026
update PCMCIA and parts availability
Hi I have error 200 & 203 per my research I need to replace the cavity and upgrade the firmware. Is the only place to get the upgrade PCMCIA and replacement cavity directly from Zeiss or are other options available?
Sun Apr 12 2026Reply from visualmed
Hi,
You need replace the cavity, only, if you want we can replace new cavity
Mon Apr 13 2026Reply from nixcamic
You can sell me the cavity or repair the machine? Where are you located?
Mon Apr 13 2026Reply from visualmed
Hi,
Wecan sell new cavity or we can change the cavity, we are located in Spain
How can I contact you privately?
Thu Apr 16 2026Reply from Jlinton
Jlinton
On the ZEISS VISULAS YAG III, your research is basically correct.
Error 200 = energy shutdown issue
Error 203 = pulse shutdown, very often end-of-life cavity
So yes — typical fix is:
Replace cavity (laser head)
Update firmware (usually via PCMCIA)
As for sourcing:
Official route (Zeiss) ? safest and most common
  • Correct cavity
  • Proper firmware version
  • Calibration support (you will need alignment + power check after)
Third-party options do exist, but:
  • Refurb/used cavities are out there through brokers/independent service
  • Firmware PCMCIA cards are harder to find and usually not shared publicly
  • Alignment requires special tools + power meter, so even if you get parts, install isn’t trivial
