Thu Jun 25 2026
NIBP air leakage
Greetings Engineers The above mentioned patient monitor display "air leakage"error everytime NIBP is carried out. I changed the NIBP accessories with the one that is working but we still have the same results"air leakage". Please what can I do? I am a biomedical engineer from Cameroon working with Mbingo Baptist hospital. Thank you Waiting
Equipment: Datex-Ohmeda cardiocap/5
Mon Jun 29 2026Reply from Emily Vitkovitsky
Emily Vitkovitsky
Ampronix
Prescotts
Sage Services Group
Fri Jul 10 2026Reply from jdeater
You will probably need to crack open the case on the unit. find the NIBP tubing and carefully trim each end where they connect to nipples. The tubing has most likely relaxed over the years and is not tight on the nipples anymore. I simple trim of a half cm or a little more and refit them on should remedy your leak issue.
Mon Jul 13 2026Reply from BrentS
BrentS
Typical leaks are usually the cuff, hose, hose o-rings or a combination of. Use Snoop or soapy water to look for leaks or swap out with a known good working set.
If none of the above are the issue, you'll have to check for internal leaks. Usually the pump, it's tubing or both have will have leaks and require replacement. This monitor is very old and past EOL. I would suspect the pump has leaks. You may have a hard time finding a replacement pump. If you do replace the pump, you're required to perform a pump calibration procedure.
