This is short and simple as I'm sure most of you have work to do. First thing is to look at the back of the Excel V laser in the right upper corner for a 5mm hole. Please see attached image. Use a long allen key (4 or 5 mm) and insert it into this hole. It will go in pretty far until you get to a stop. Once you feel it stop, firmly press the allen key in and the right panel will pop open. It is just a spring-loaded button that locks it in place. Once you see the panel pop out you can see what you need to do to get the rest of the panel off.
Sat Jul 18 2026
How To Remove Cutera Excel V Panel W/ Pictures.
Tue Jul 21 2026Reply from MapleTreeBiomed
Hey LS 6,
Ah, it's like the old Lumenis PowerSuite units with the hole under the front to press up with an allen key to open the front. Nice.
Tue Jul 21 2026Reply from LS 6
