Tue Aug 04 2026
Erreur 046
"I have a Cynosure Icon. The system starts normally, but after several minutes of operation it displays Error 046 – Discharge Temperature. The machine has been allowed to cool, but the error keeps returning. I suspect a cooling pump or coolant circulation problem."
Equipment: Cynosure icon
Wed Aug 05 2026Reply from Emily Vitkovitsky
Emily Vitkovitsky
Wed Aug 05 2026Reply from Jlinton
Jlinton
Error 046 – Discharge Temperature on the Cynosure Icon usually points to a cooling issue.
I'd check:
  • Coolant level and look for leaks
  • Coolant pump operation and flow
  • Fans and radiator for proper airflow
  • Coolant filter (if equipped) for blockage
  • Temperature sensor connections
If the error returns after the unit has cooled down, I'd suspect poor coolant circulation (pump or blockage) or a faulty temperature sensor rather than the laser itself.
