Mon Aug 31 2026
XEO Cooling System Failure -- Pump and Filter Replacement / Service Technician Needed
I have a 2016 Cutera XEO. After a heavy treatment session, the system developed 322 and 367 error codes and the cooling system stopped circulating water. A local technitian diagnosed a failed pump and water/particle filter and quoted me $4,600 for the repair. Before proceeding, I would like to get a second opinion from an experienced XEO technician. I am particularly interested in recommendations for an independent laser technician in Southern California who has experience servicing Cutera XEO systems . I would also appreciate advice on the correct pump/filter part numbers and whether this repair is reasonable for a 2016 XEO. Thank you!
Equipment: Cutera - XEO Platform
Mon Aug 31 2026Reply from Esjay
E322 could be caused by a few problems: if your IPL/dummy plug is not properly connected, a faulty pressure switch or a water level sensor.
1. Make sure that the connector is fully seated.
2. Pressure switch can be adjusted with a small set screw if accessible.
3. Replace a water level sensor that's inside a reservoir.
It is plausible that a water pump is malfunctioning, but in my experience it is rare.  New DI and water filters are recommended every 12 months of service.
Mon Aug 31 2026Reply from Emily Vitkovitsky
Emily Vitkovitsky
MedWrench is an informational community, we do not service, sell parts or equipment. We do however work as the link between you and a service company. Browse service companies for your equipment or fill out a REQUEST FORM and we will help find a service company for you!
Tue Sep 01 2026Reply from Erik J
Where are you located?
Thu Sep 03 2026Reply from Dr. Tatiana N
I am in San Diego.
Fri Sep 04 2026Reply from Erik J
Sorry for the delay in my response.  I can be there on Monday.  Feel free to text me at 720-675-8967
