ac line is good however none of the control functions work
Tue May 17 2011
No power
Tue May 17 2011Reply from Radiation Man
What is it? If it is an X-Ray room check your DC power supplies. The console usually runs on DC.
Wed May 18 2011Reply from brianric
Wed May 18 2011Reply from GaryBiomed
Doesn't this unit run on battery only?
I think if the batteries are shot, the unit doesn't work.
It has the twist lock power cord, correct?
STERIS
1-800-333-8838
Fri May 20 2011Reply from GaryBiomed
I actually meant the other side of the cord, that twists into the base of the unit. I bet that batteries are bad.
But I would call
STERIS
1-800-333-8838
Mon May 23 2011Reply from Bio-Med-Mac
Mon May 23 2011Reply from brianric
found bad battery also remote function relies on good battery. Thanks all for responding.
Tue Oct 18 2011Reply from Ron Pruitt
The batteries should be changed every couple of years, but I agree with some of the above posts, Power Supply. Try to get the OR staff to use this while unplugged, then plug it in at the end of the day to charge or as needed. This will work the battery thus extending the life of them. Battery Part number is P764331223, and the charger part number is 426637598. Cant find the power supply number but Steris Tech support will help.
