Wed May 18 2011
Versa care beds
Should draw sheets/attends be used when using Versa care beds? or is just a fitted sheet all that is required?
   RE: Bed Report Post
Fri May 20 2011Reply from GaryBiomed
GaryBiomed
You may want to call Hill-rom Call 1-800-445-3730 for More Information on the VersaCare® Bed [url=http://www.hill-rom.com/usa/VersaCare.htm]http://www.hill-rom.com/usa/VersaCare.htm[/url]
Tue May 24 2011Reply from Todd S
Todd S
Are you talking with low air loss? If so, do not use a fitted sheet. Use a flat sheet. If you need a chuck, use a paper chuck.
