Wed Jun 15 2011
GE Instrumentarium Performa MGF-110
I am installing 2002/2003 GE Instrumentarium Performa MGF-110 and I am getting error message E.02 and U.FL indicating I am not getting any high voltage through the system. I am thinking is the HV Unit or tank. Can someone help before I spend money to purchase a replacement part that is not going to solve the problem
   RE: Mammography Report Post
Mon Jun 20 2011Reply from GaryBiomed
GaryBiomed
You may want to Call GE    Tech support 1-800-437-1171    Parts 1-800-558-2040         or     Unisyn    Local: 303-384-ECHO (3246)    Toll Free: 877-386-ECHO (3246)     [url=http://www.echoserve.com/repair_mammography.php]http://www.echoserve.com/repair_mammography.php[/url]        or        Maybe [url=http://www.blockimaging.com/]Block Imaging[/url]    1-877-621-2887
Mon Jun 20 2011Reply from Gabe Viscomi
We have an engineer familar with these units and would be able to help you. We have parts available as well. Give me call at 517-999-7020. Gabe Viscomi Block Imaging Parts & Service
Thu Jun 23 2011Reply from Cell Dyn Ruby
Thanks Gabe, I left a message but I haven't heard from you. Below is what the technician who is working on the installation has been able to get. I hope your technician can help me get the right part needed if any. Please see below. Also my number is 973-444-6957. I will try to call again tomorrow. -------------------------------------------------------------------------------- There is no problem with the power. But on the filament board the LED H3 (E.02 Error) Tube Fail Signal lights. This ocurrs during High Voltage break down according to pg.3-25 sevice manual.
Fri Jun 24 2011Reply from Gabe Viscomi
I'm sorry to hear that! I've searched through my voicemails but haven't been able to find where you called. Regardless, let's touch base today to help you with the problem you're getting. Thank you!
Tue Aug 06 2013Reply from Rafa
Hi, maybe E.02 was ocurred because the large filament is opened, put the magnification system, so the large filament change to the small filament and check the equipment, the UFL is refer to the integration time is less than 20 miliseconds, but whit the error 02 you cant x ray emitting
