Thu Aug 02 2012
LAMP CHECK ERROR
Dear sir,
In my instrument, otheroptions, lamp check is giving a value of high ie 171.966 and no absorbace values are getting but only 0.000 always.  How to correct it? normally lamp check value comes around 43.000.  Is there any problem with photometer board? kindly revert back
tojo
Thu Sep 06 2012Reply from sachidan
check powersupply to photo diode board
171 is literally the infinite value that means , photo diode board problem
Mon Sep 10 2012Reply from tojojerome
Dear sir,
do you have service manual for BTS series of instrumets? If you can provide this will be very much helpful for me
Sat Nov 02 2013Reply from tojojerome
Dear Sir,
Problem solved....it was due to ribbon cable connectivity problem with photodiode.
thanks
Sat Nov 23 2013Reply from Van Tien
well done . i had a same your problem  . thanks for your comments.
