Tue Aug 07 2012
TILT MECHANISM
Scope will only tilt AWAY from surgeon, not towards surgeon. This is backwards.
   RE: Microscope-Surgical Report Post
Fri Jul 12 2013Reply from Peter Hanson
The microscope will tilt towards the sergeon if required as the tilt axis is adjustable and can be clamped in any position.
The range of movement is around 15 degrees so this can be set equally forward and backward or any variation needed adjustable via a clamp knob on the side of the axis.
Peter Hanson
Brisbane Australia
