Is anyone else having problems with this unit? They provide a convenient test point jack on the side for 1 ohm (and also for 200 microamps) and the test works fine, t h e r e....but, if you connect this same cord to the female ground on the test receptacle, you get erratic resistance. At first I thought it might just be the chs gnd switch, but that checks good. I sent it to our cal lab and they say that they are unable to get any support from Netech. I have had this problem with 2 different units over the past six months. I haven't contacted Netech yet, by the way, I was just wondering if this is a common occurance.
Fri Aug 10 2012
