Is there an available video output plug on the c512 system to send video to a second monitor mounted on the wall without using a video splitter.
Mon Aug 13 2012
Repeater Monitor from Ultrasound system
Tue Aug 14 2012Reply from GaryBiomed
There's a BNC composite on the back and you can get adapters for the BNC RGB
I used a s-video splitter from the printer to a monitor on a boom.
Wed Nov 28 2012Reply from codynutt
I am a bit confused...I am trying to send video out of our 512 to a second monitor. I have the bnc to rgb cable but am not sure what to hook where?? The cable has 5 bnc connectors (red, green, blue, black, grey). On the back of the 512 I can only get video to come out when I plug the green cable into the port labeled Colorchroma (but the image is in black and white). I need it to be in color...do you know if I am supposed to plug the other cables into something...or if I am doing this totally wrong? Thanks for the help!!
