Tue Aug 14 2012
MP30 Touch Screen Calibration
Screen will not calibrate... monitor will not accept touch of 2nd target in Cal Mode.  I replaced the bezel and touch sceen with Philips parts, same result.
Wed Aug 15 2012Reply from MedWrenchManager
MedWrenchManager
 Probably needs a new touch panel. I would call Philips support at 1-800-722-9377 and see if they have a better idea.
Answer provided by Jeffrey E., Biomedical Equipment Technician at Sisters of Providence Health System.
Wed Aug 15 2012Reply from Darryl LeRoux
Philips have advised the HIF Board should have also been replaced. I ordered one and will pass on the results when it is installed.
Wed Aug 15 2012Reply from Sevice manual
HI.
Have you ever log in to service mode to fix this problem. I think this function is disable. Please try below steps:
To permanently disable touchscreen operation:
a. Enter Service Mode.
b. Select Main Setup
c. Select User Interface
d. Change the Touch Enable selection to no.
To re-enable touchscreen functionality change the Touch Enable selection to yes.
Thanks
Thu Aug 16 2012Reply from Darryl LeRoux
Hi, Tried your suggestion - unfortunately, did not work.  But thank you for your help.
Darryl
Fri Aug 17 2012Reply from Darryl LeRoux
HIF Board repalcement solved it.
Fri Jun 21 2013Reply from marktutone
i had the same problem.
I removed power cord and batteries.
Pressed the power button for 10 seconds.
I then put the batteries in connected power and calibrated the screen.
Works great
