Does anyone know the procedure for changing the cmos battery on this system.
CMOS battery
As with most CMOS Batteries, standby power must be present to retain the BIOS settings. With the cord plugged in to wall power and the main circuit breaker in the on position, you may remove and replace the battery.
**Note: the battery is in a fairly tight spot, so be carefull and use appropriate ESD precautions.
If your battery is dead or did not have enough voltage to retain BIOS settings, then all you have to do is boot into BIOS and load the GE settings.
