Mon Aug 01 2011
signal interference! (noise)
I have an C-ARM mechanical with signal interference. Model is BV25T. Please Help me!
Tue Aug 02 2011Reply from Radiation Man
Radiation Man
Are you meaning there is noise in the image. Quick fix for Video noise; swap to a different monitor if you have one and see if the noise is on that one also. If so check all image chain connections, clean and de oxidize if it is older (which a BV 25 is ) Add a ferrite choke to the video cable if you do not have one. You may have a noise suppresion capacitor on the video board failing, so either replace the board or go down to component level and find it.
