Do you have the factory administrator password for stat fax 3300 so we can use programming key
Tue Aug 09 2011
forgot password
Wed Aug 10 2011Reply from MedWrenchManager
The administrator password is set by the user. Hold down the #5 Key when powering the instrument on to access the password setup feature (You can release the key after you hear the beeps). A screen will appear allowing you to change the password or turn the password feature off.
(This answer was provided by Mike Standt, Stat Fax Support via LabWrench)
