Per manufacturer this battery needs to be changed every 2 years. The problem is I can't find where it's located. I consulted the service manual and I'm still clueless. Help please!
Lithium Ion Battery Change (bi-annual)
If you follow the instructions in the manual, when you get the control board tilted out you will find the battery on the back wall of the mother board, it is on the right hand side enclosed in stainless steel and the battery is the size of a remote start battery for a car. it is encased in yellow plastic. hope that helps- i had a hard time too! (LIR2450)-
Quote Jessica M
Figured this was the battery, but I had a colleauge swear it wasn't. Thanks for replying.If you follow the instructions in the manual, when you get the control board tilted out you will find the battery on the back wall of the mother board, it is on the right hand side enclosed in stainless steel and the battery is the size of a remote start battery for a car. it is encased in yellow plastic. hope that helps- i had a hard time too! (LIR2450)-
