Tue Feb 26 2013
Heraeus multifuge 3S Error 26
I have lost the booklet that came with our multifuge, so was wondering if you could help me out by telling me what Error 26 means please?
Thank you very much,
Erin
Wed Feb 27 2013Reply from MedWrenchManager
MedWrenchManager
You should try contacting Ozark Biomedical, they may be able to help
Wed Feb 27 2013Reply from ErinFirmin
Thank you :)
Wed Feb 27 2013Reply from C. Mash
C. Mash
Error 26 states "Time out - latch close" which usually is the latch motor sensor pcb. The best solution for this would be removing the hub attached to the latch motor shaft and cleaning the magnets on the back side of it. If that does not correct the issue, the sensor pcb may need replacing. Thanks again for using Med-Wrench.
Ozark Biomedical
Senior Technical Specialist
800-457-7576
Thank you so much for your reply, I will definitely try that! :)
