Wed Mar 20 2013
Mosaic computer lockup
Mosaic computer freezes intermittently causing the inability to transfer planning data to the varian 2100C unit.
   RE: Linear Accelerator Report Post
Fri Mar 22 2013Reply from MedWrenchManager
MedWrenchManager
Troubleshot an IC handler that was locking up for three weeks straight once. Swapped CPU/Interface/Servo boards, etc... Turns out the most obvious thing (that we thought had already been verified as it just came from PM) is one of the cooling fans had died. So the handler would run from 4-6 hours until it overheated then shut down. I doubt your issue will be this simple, but it's always worth "double covering" the basics first. Good luck.
Answer provided by Steve H., Hospital Service Technician at Universal Hospital Services, via LinkedIN
