Dear:
How many head shots and what is the average duration of the head and it fails?
In to GENTELASE SERIES with Láser de Alexandrita
Thanks
Dear:
Thanks
The life of the laser head is ultimately determined by it's output. If the unit is serviced every six months, trends for efficiency, overall output power, regular errors, etc. are clear, and help determine when a catastrophic failure would likely occur, or at least when high dollar repairs should be performed. Warranties are also available through third parties that cover laser heads.
Is possible that the head of a laser last three million and is due to change, with its maintenance every 6 months and all technical support after sales, we comment because my laser head alone will drive 3.5 million shots and according to the technical these heads only last 3 million, I always consider the change head laser? thanks
3.5million shots is far greater than the reasonable life expectancy of the flash lamps, and other components in the head. On average, flash lamps lose peak efficiency after about 250,000 shots. Other laser head components age similarly.
