typically what happens are a couple of things:
1: The battery backup (the black rectangular thing) on the gantry mpu is dead...
2: If it is dead (you have to remove mpu to check on the back of the board) you can use a phone battery (3.5 vdc) in its place. ie red/black wires and solder to the mpu where the battery pack used to be
3: once you replace the battery you must go into dos and run gantcal.exe and restore the cal and limit files to the gantry mpu
4: once you complete this you must recal the gantry and run gantcal again and save the results
5: it is assumed that you know anything about what im saying and you have a basic understanding of how to move around in the file structure.
There you have it.
