This device fails the self-test at around 30%. The error code is 18 “centrifuge stall”. I hit “yes” to restart the self-test and it fails one or two more times, but eventually passes.
What is the issue? Is this something I should be concerned about?
Yes this is something you should be concerned about. This could be an issue with the motor on the unit. You could have a dead spot in the motor and by basically restarting the self test you are getting luck some times and blowing past the dead spot and the unit is passing. I would get this unit checked out by someone who is factory trained on the unit. Soaring Hearts works on these types of devices and can advise you further. You can reach them at 1-855-438-7744
