PAPER RUNNING IN WRONG DIRECTION. LOAD PROBLEM
Place the roll of paper so when you bring the end of the paper upward and over the door the pink grid is up and you see Burdick printer at the bottom of the paper.
Hi,, will u please carefully explain WHERE to feed the paper so it can print. I cannot find the answer anywhere and we need this for our class. HELP! Thanks! This is for the Burdick EK10
Open the paper door and place the paper in the tray. lift the end of the paper into the air about 6 inches. slide the door gently to the right. Drape the paper over the door. The paper must have the pink grid up and the larger white area at the top. Push the door completely closed. If you still have a problem, contact Mortara Instument and they can help you. 800-985-8422 option 2, 2, 1
