Hi,
can anyone help me in locating a service manual for a datascope cs300. I'm a inhouse biomed trying to perform PM on a ballon pump.
Hi,
I do have the manual at home. Please let me know your email and i can send it to you later tonight. I can tell you this though.the pm is involved. you will need the following items to comlete the pm.
1. trainer simulator. this simulates ecg for the machine and other functions. you should have one that came with the machine or it might be hiding in the department some where as a nurses paper weight. its a white box that plugs into the side of the balloon pump. If you cant find it you can order one from the OEM.
2. a balloon catheter. you can get one from the department.
3. A rebuild kit for the pump motor. this rebuild kit can be purchased through the oem.
4. fluke meter.
hope this helps.
You will also need a cather extender for a 40cc IAB. A calibration chamber part number:0683-00-0314 and a 60cc. The fiber optic test module part number: 0992-00-0245. Please if nothing else replace the batteies part number:0146-00-0039. Need more help den3eog@gmail.com. Good Luck!! Sean
