- All Categories
- Patient Monitoring
- Apnea Monitor
- Blood Glucose Monitor
- Blood Pressure Monitor
- Carbon Dioxide Monitor
- Data Management Systems
- Electroencephalograph (EEG)
- Electromyograph (EMG)
- Fetal Monitor
- Medical Gas Monitor
- Modules
- Multiple Medical Gas Monitor
- Oxygen Monitor
- Pacemaker
- Patient Cables and Leadwires
- Pulse Oximeter
- Sphygmomanometer
- Telemetry-Central Station
- Temperature Monitor
- Vital Signs/Multi-Parameter
- Home
- Videos
- Pulse Oximeter
Pulse Oximeter Forums
BC Group unveils its NEW FSX-1101 Digital Pulse Oximetry Simulator. The FSX-1101 can be connected to your BC Biomedical NIBP-1000 Series, PS-2100 Series or PS-2200 Series Patient Simulator via the auxiliary port (by using the provided cable). This allows for a synchronized SPO2 and ECG simulation for your monitors. Visit www.BCGroupStore.com for our full line of products, datasheets and more.
RE: BC Group - FSX-1101Watch as we show you how to operate our new FSX-1101 Digital Pulse Oximetry Simulator. Visit www.BCGroupStore.com for our full line of products, datasheets and more.
RE: BC Group - FSX-1101Watch as we show you how to operate our new FSX-1101 Digital Pulse Oximetry Simulator with the NIBP simulator. Visit www.BCGroupStore.com for our full line of products, datasheets and more.
Covering the most common SpO2 cable connectors used in most Healthcare Clinics. With Free Downloadable PDF Cheat Sheet. This information with help you identify which connectors you will need…and hopefully take the guessing game out of your ordering process.
Sp02 Cable Connector Cheat Sheet Available for download here:
http://pacificmedicalsupply.com/pac-f...
Today we are going to walk you through the most common SpO2 connectors used on patient monitoring equipment.
Nellcor DB9 OxiMax
The DB9 connector is the most common connector for finger sensors. It can be identified by 9 pins and the color Purple
Philips D-Connect
A D-Connect connector by Philips can be identified by 8 pins and the color Blue
Datascope
A Datascope connector by GE can be identified by 8 pins and the color white
GE Ohmeda
A GE Ohmeda can be identified by 10 pins and the color gray
GE Marquette
A Marquette connector has three different styles
The GE Marquette standard Ohmeda can be identified by 11 pins and the color blue Blue
The GE Marquette with Nellcor OxiMax can be identified by 11 pins and the color blue
The GE Marquette with Masimo can be identified by 11 pins and the color Blue
GE Hypertronics Datex-Ohmeda
The GE Hypertronics Datex-Ohmeda connector can be identified by its 7 pins and the color Black
3M
The 3M connector has four different styles.
The Nellcor 3M OxiSmart can be identified by its 14 pins and the color Gray
The Nellcor 3M OxiMax can be identified by its 14 pins and the color Purple
The Masimo 3M LNC connector can be identified by its-14 pins and the color White
And the Masimo 3M LNC-20 connector cab be identified by its 20 pins and the color Red
Masimo LNOP
The Masimo LNOP connector can be identified by F-Tab and the color White and Red
Masimo LNCS
The Masimo LNCS connector can be identified by 9 pins and the color gray
To learn more about SpO2 cable connectors, to cross reference, view all our in-stock cables and to download a free SpO2 and Extension Cable Catalog, visit pacificmedicalsupply.com/PacFaq
Nonin Medical recognized for infleuntial contributions in medical technology. Nonin was awarded the Medical Technology Award at the tenth annual Tekne Awards, put on by the Minnesota High Tech Association (MHTA) in partnership with Enterprise Minnesota and LifeScience Alley, for its Onyx II, Model 9560 fingertip pulse oximeter with Bluetooth wireless technology .
RE: Nonin - Onyx II, Model 9560
