- All Categories
- General
- Air Cleaners
- Alarm-Occupancy
- Apheresis Units
- Apps
- Audiometer
- Audiometric Booth
- Battery Testing
- Beds/Stretchers/Mattresses
- Blenders/Regulators/Flowmeters
- Brachytherapy System
- Continuous Positive Airway Pressure Unit (CPA)
- Dental Equipment
- Dictation System
- Electronystagmograph
- Enteral Feeding Pump
- Exam Tables & Chairs
- Facility Boom
- Hand/Foot Switch System
- Handpiece-Dental
- Headwall System
- Hemodialysis Unit
- Humidifier
- Hyperbaric Chamber
- Infant Incubators & Warmers
- Information System
- Infusion Pump
- Irrigation/Distention System
- Laser
- Lensometers
- Lift-Patient Transfer
- Light Source-Fiberoptic
- Lithotripter
- Medical Monitor
- Medication Management System
- Miscellaneous
- Nurse Call System
- Ophthalmic Equipment
- Oxygen Concentrator
- Patient Identification and Security System
- Peritoneal Dialysis Unit
- Phototherapy Unit (Hyperbilirubinemia)
- Point-of-Care Analyzer
- Pulmonary Function Analyzer
- Recorder
- Respirator-Air Purifying
- Scales
- Sequential Compression Device
- Slit Lamp
- Spirometer
- Sterilizers/Autoclaves
- Thermometer
- Traction Table
- Traction Unit
- Urodynamic Measurement System
- Ventilator
- Veterinary Equipment
- Vision Screener
- Warming Unit
- Warming/Cooling Unit
- Washer
- Wheelchairs
- Xenon System
Analyzer Measurement & Simulator Forums
Watch as we show you how to operate our new SA-2000 (Safety Analyzer) series.
RE: BC Group - SA-2000 SeriesThe SafeTest 99 is a compact and reliable electrical safety analyzer which allows you to carry out patient lead leakage testing in accordance with NFPA-99.It features accurate high current, low energy ground continuity testing with secondary ground warnings to ensure valid tests.You can quickly step-through test routines with minimized power breaks and have manual control of fault conditions. The SafeTest 99 comes complete with a patient lead adapter box and a protective carry case.
RE: Rigel Medical - SafeTest 99Uni-Therm is versatile and compact yet offers safer, faster and more accurate testing of electrosurgical generators enabling you to meet international and manufacturer specific test requirements simply and efficiently.
RE: Rigel Medical - Uni-ThermThis video is a "how to" on accomplishing a preventive maintenance (PM) of a Covidien, ValleyLab, Force FX ESU using the Rigel Medical Uni-Therm analyzer. Automated test sequences includes tests for REM/CQM, HF leakage and ESU power. On screen connection diagrams and pass/fail criteria simply the test process. Test sequences are available for other Covidien e.g., ForceTriad, and ConMed surgical generators
RE: Rigel Medical - Uni-ThermIntroducing the Multi-Flo from Rigel Medical, an easy to use infusion pump analyser allowing you to test up to 4 infusion devices simultaneously across a range of 10¼L up to 1500mL per hour. The Multi-Flo delivers unique accurate and instantaneous flow measurements even at low flow rates, enabling the user to test twice as many infusion devices within the same time period as other volumetric based analyzers.
RE: Rigel Medical - Multi-FloThe Rigel SafeTest 60 is a robust, reliable and dedicated medical safety analyzer. It is ideal for testing high volumes of medical and laboratory equipment that does not require patient lead testing, such as beds, hoists, infusion pumps, CPAPs and centrifuges etc.
RE: Rigel Medical - Safe Test 60
