Anesthesia Equipment Forums
Add Anesthesia Equipment to My Bench8 Results
Apr 16 2020
Mar 19 2020
Feb 25 2015
Feb 25 2015
Feb 25 2015
Feb 25 2015
Feb 25 2015
Feb 25 2015
How to reprocess components of the Fabius GS premium which frequently need to be cleaned
RE: Draeger - Fabius GSBefore being dispatched to the customer, each Prima 465 anaesthesia system must complete hours of detailed testing.
RE: Penlon - Prima 465The Avance CS² User Interface was designed with intelligent menus that reduce set-up time and help minimize training needs. We analyzed Carestation data logs reviewing keystrokes and menu interactions to design an intuitive user interface that truly fits the way you work. Featuring the same engaging touch screen technology found on most consumer digital devices today, the 15-inch ventilator display makes navigation and operation easy. With time-saving quick picks, flatter menus and tunneling alarms, you can directly make adjustments like Oxygen and flow settings with one touch. Features like the automatic checkout were designed to be fast and responsive, yet can be bypassed in an emergency. We even made starting a case a simple two-step process: simply select Start Case, set the ventilator and confirm settings. Quick picks, preset case defaults and the option to use patient age to set ventilator are just some of the time saving features built into the Avance CS² user interface.
RE: GE HealthCare - Avance CS2© 2017 MedWrench, LLC. All Rights Reserved
